I was originally going to leave my canister filters in place and install a 30 micron filter before the sensor.
Well, I wound up removing the canister filters all together since I couldn't find a 30 micron pre-filter. For filtration, I have the 10 micron and then the screen at the carb.
My issue is the need for a pulsation damper after the sensor and before the pump. The way I mounted the Racors, I don't think I have enough clearance for the damper to fit. I'm just looking at the pic online and they look to be pretty tall. I made a bracket mount which is attached to the underside of my deck.
I called Floscan and they said w/o a damper, my low/idle readings will be off. Do I care?
I'm more concerned about my cruise speed/consumption but if I have to re-work the bracket and fuel lines to get the damper installed, I'll do that.
They're suggesting the damper and then a 45 fitting before the fuel line so that the damper is always on the "downhill" side and flush full of fuel. I hate to add two more things for the fuel to flow through.
I have 454, carbs with new mechanical fuel pumps.
Bob
Bob
