Hi Guys,
Trying to remove both trim cyl. pins at the transom shield on a DP-S with a grease gun no luck. Should I heat the shield, try making a puller adaptor or break down and buy the V/P pn 884978 tool? The shield will be refinished so I'm not worried about burning the paint with a torch. Also is there an aftermarket tool that I could use as a substitute for the V/P one?
Thanks,
Jon Allen
Thanks,
Jon Allen
