Re: Ignition system on a 1991 Johnson...
Nick... The inner portion of the starter that turns is the armature. The bottom portion of the armature that the four brushes ride upon is the commutator. The stub shaft that is mentioned, I would assume is the short portion of the armature bearing shaft beneath the commutator.
The starter overheat thing..... it states in the manual somewhere, in not so many words, that it is recommended that the electric starter be allowed to cool down after being in use for 20 seconds. This is to avoid overheating which could melt the solder that connects the windings to the commutator. Not an everyday occurrance but it does happen from time to time.
I may have lost track of what's happening here but I assume that the stator was faulty and replaced but you still have no spark. If so, and if you might have overlooked Daselbee's suggestion about disconnecting the RED electrical plug (I saw no mention of doing that).....
Disconnecting that RED plug eliminates the kill Circuit resulting in the ignition system being fully active.
Remove the spark plugs, then disconnect the large RED electrical plug at the engine. Rig a spark tester whereas you can set a 7/16" gap for the spark to jump. Crank the engine by using a small jumper wire from the battery terminal of the solenoid to the small 3/8" nut terminal of the solenoid that energizes the solenoid. If you have spark with that RED plug disconnected BUT not with it connected, the usual problem is a shorted ignition switch.
To test the switch, reconnect that RED electrical plug, then disconnect the black/yellow wire from the ignition switch. Also make sure that the black/yellow wire is disconnected from the kill switch. If you have spark with that wire disconnected BUT no spark with it connected to the ignition switch, replace the ignition switch.
No spark tester? Build the following.
Spark Tester - Home Made)
(J. Reeves)
A spark tester can be made with a piece of 1x4 or 1x6, drive a few finishing nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere. Use small alligator clips on the other end of the wires to connect to ground and to the spark plug connector that exists inside of the rubber plug boot.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
Let us know if you've performed this test and what the results are.
Note: The flywheel nut must be torqued to 145 foot pounds, otherwise the flywheel key will shear which effectively throws the engine out of time.
