Re: Ignition system on a 1991 Johnson...
nick, I discovered I had eratic spark on different cylinders on different days, sometimes no spark, sometimes 1 or 2 cyl's. had spark. it drove me bonkers. I bought a cheap( $8.00 ) I think, analog meter. I looked in my factory manual under the heading of power pack testing , stator testing & timing sensor testing. In the man. it tells you how ro ck your voltage from each component, how to ohm each component, & how to ck for grounding of each component. i made a ground with 10 gauge wire & wrapped around each plug,after removing them , & connected it to my engine block, so I could crank my motor to ck volts & grounding without starting motor. The cheap volt meter didn't work very well for voltage, but it worked good enough to ohm out each pin from the stator & timing sensor. It also worked to see if any curcuit was grounding with another curcuit in that component. the fac. man tells you what reading you should have for each test. I had previously replaced pp.,rectifier,stator.plugs, plug wires. Still couldn't get it to run right. Three weeks later I took it to a marine mechanic. He replaced my new pp, stator, rectifier, & plugs & charged me $2500. It still didn't run right. After returning it to him three times & having a fit with yelling & a little cussin', I decided all he knew to do was replace parts until he finally got to the right one that needed replaced. I can do that myself!! After putting my 3 wek old pp back on it, I cked the ohms, & grounding in the stator & timing sensor, finding the numbers didn't coincide with the fac. man. for the timing sensor. I decided to bite the bullet & replaced the timing sensor. (It was the original one from 1991) It started & ran like it used to before all the trouble started. I can't say your problem is the timing sensor but I know you have a manual from previous posts. go to the ignition component testing section & ck. the pins per man. specs. for grounding & ohms. I bet you find the sensor is bad.OEM price is around $400. marineengine cdi price is $300. neighborhood. After replacing timing sensor I did the joe reeves method of setting the static timing, then double cked it at the lake the doug selby way, Everything works great now. Good luck, jeff
