Do you have a wiring diagram? It would troubleshooting alot easier. The disconnected wires: the black wire is a ground and the purpe one should be 12 VDC. You can test w/a meter. On the OD is the trim position sender wiring disconnected? I would tape over any bare wires to prevent an accidental elec. short.
I believe the oil pressure switch only supplies 12 VDC to the elec. fuel pump after the engine starts. It's a safety issue so that the pump won't run if the engine stalls and/or loses oil pressure. The pump gets gets 12 VDC from the starter circuit only when the ignition key is in the start position.
