MarineEngine.com - Your online store for all types of marine engines and boat parts.
PHONE ORDERS
Monday - Friday
9:00 AM - 5:00 PM EST
Click for TOLL-FREE Number
Secure Online Payments
Special $9.95 Flat Rate Shipping
(800) 209-9624 | Home | Contact | Shipping | Returns | Cart View your shopping cart.
Search by Part Number
Enter engine/drive part number.
Original & matching parts for sale.
Manuals & Accessories
Shop by description, item number
or manufacturer's model number.
Why shop with us? Check our reviews! Why Us & Reviews   Boat Repair Forum Boat Repair Forum   Boat Video Gallery Video Gallery
MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 2 of 2
  1. #1
    Default 1978 Mercury 90 HP No fire to plugs
    HAVING A REAL PROBLEM, PLEASE HELP!! I have a 1978 90 HP Mercury outboard and I'm not getting any fire to the plugs. I checked to see if I could get any fire out of the coil and I'm not. Should the green wire to coil show any voltage? How do I check coil? What would my next step be?
  2. #2
    Join Date
    Dec 2009
    Location
    Yuma, AZ, USA
    Posts
    107
    Default Re: 1978 Mercury 90 HP No fire to plugs
    If yours is an inline outboard with a Distributor this might help.If not disregard this.
    MERCURY BATTERY-POWERED CDI TEST FOR DISTRIBUTOR MODELS
    This test is for the 332-2986 switchbox used from 1967-1978 on all the inlines.
    This test assumes your coil is good (problems with CDI coils are rare).
    DISCONNECT BATTERY
    1. Turn off ignition;
    2. Disconnect all 3 distributor wires on the Port side of the switchbox (and the “mercury switch” if present);
    3. Remove the High Voltage lead from the ign coil to the center of the dist. cap (remember it unplugs from the coil and unscrews from the cap);
    4. Reconnect the H.V. lead to the COIL only;
    5. Position the free end of the HV lead approx. 3/8" from ground (block, shrouds etc), and find a way to hold it there;
    6. Jumper the brown and white terminals on the distributor side of the switchbox to each other.
    RECONNECT BATTERY
    7. Check that you have +12V at the red terminal (even with the ign off);
    8. Turn on ignition and verify +12V at the white terminal (same side as the red terminal);
    9. Ground the black terminal on the distributor side of the switchbox - this should cause a spark each time you touch ground.
    If you get spark with the distributor bypassed, and it won't fire with the distributor connected, the trigger is bad and the entire distributor housing assy must be replaced.
    If you get no spark using the test, the switchbox is probably bad. In that case, be sure to check for correct power on the switchbox, check all connections, and check the coil's resistance to make sure it's OK."
    [FONT=Impact]Best Regards[/FONT]
    [FONT=Impact]Steve[/FONT] ;)
Similar Threads
  1. no fire on hot plugs 1983 70 hp
    By scortyduck in forum Mercury Mariner Outboard Forum
    Last Post: 06-12-2010, 04:03 PM
  2. 115 MERC NO FIRE ON PLUGS
    By ddh1947 in forum Mercury Mariner Outboard Archive
    Last Post: 07-04-2008, 07:54 PM
  3. No fire to plugs
    By fixitman in forum Volvo Penta Gas Archive
    Last Post: 03-21-2008, 08:18 PM
  4. 1978 mercury 140 hp 1400 no fire to plugs
    By poundermark in forum Mercury Mariner Outboard Archive
    Last Post: 06-26-2007, 09:21 PM
  5. 1976 Inline 6 150 Mercury not getting fire to plugs
    By rodneyray in forum Mercury Mariner Outboard Archive
    Last Post: 08-29-2006, 01:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
