'91 Crusader power loss issue posted first on 9 / 5. Had the marinas gas mechanic there today. Found timing way off on port side, like 18 degrees ! Makes no sense unless it was set wrong due to counter rotation. Or maybe something moved ? Anyway, runs much better, but still tops out at 3700 with both engines still even. Did a complete compression check, not as good as I would like, but both engines are consistent.
Flushed both engines with reccomended biodegradable acid and that appears to have helped a lot with the hot running issue.
Going to have both carbs rebuilt, never done in twenty years, guess it's time. May also drop an inch or two of prop pitch to see if that will bring the r's up some.
Thank you all very much for your help and interest !!
