I recently did a carburetor cleaning with the dip cleaner, but the motor will not idle well. Starts fine and runs fine at higher speeds. Biggest problem is the engine dies at lower rpms when I want to change gears.
8hp 4 stroke.
I suspect I had old gas in previously; now I run the gas out.
Also I was told to clean the "emulsion tube" but I could not locate anything by that name on the parts list.
Any suggestions?
8hp 4 stroke.
Any suggestions?
