analogkid455
I have a 1983 Crusader 454 that does not crank when there is 12 volts to the coil. If I unhook the voltage it will crank, but obviously won't start because I have no voltage at the coil! WTF?
The only thing I did was put a new flywheel on the engine. It worked fine before. The only wire I disconnected was the battery cable when I did the flywheel swap. I have tried everything that I could possibly think of to get this to work. Any suggestions?
