Newbie here, thanks in advance for any and all help.
I have a 1989 Johnson (OMC) 15 hp shortshaft. This motor is in remote bush service in Northern Ontario, Canada. I have owned it since new.
I have had a number of problems of late. For years the motor would quite quickly lose power, and you could restore full power (rpm) by quickly pulling and pushing in the choke. This was solved with a new (used carb)
The new problem(s) are thus. The motor is very hard to start when semi warm, (after sitting ~1/2 hour) I haven't figured out if it needs more choke or is over choked. The second problem is, while running full throttle (full rpm) slowly, almost imperceptibly it begins to drop rpm, until it seems to be running ~80% rpm, and then slowly it comes back to full rpm, only to repeat the process. The final issue is that when the motor is tipped up, the carb drains into the lower cowl, spilling fuel into the water. I know my older (1960's vintage omc's would do that) but I have no memory of this ne doing it until I replaced the carb. My newer vintage omc's don't leak like this.
My hunch is that all three problems are related, but after tearing the carb apart time and again, I am lost for ideas. Anybody out there who has a clue to what is happening?
Thanks in advance,
Icarus
Thanks in advance,
Icarus
