Paragon Transmission HF
Doublet
Lost front seal, fluid leaked out so replaced front seal. Now all I have is reverse, forward will not engage. Any suggestions on what might be going on and how to solve the problem.
Having gone through this a few years ago. The most likely fault is " you put a gasket on backwards on the hydraulic pump". One side of the pump output pushes the gears to the forward position, the other side pushes the gears to the reverse position.
Sorry, but yes that does mean pull the transmission, take it apart again.
The gasket should lay on the mount with all the flow ports clear.
