Are you sure you have the number correct
EJR-CDR would be a 1986 Evinrude Junior where CD are the date letters for '86
That being so:
Operators manuals should be available from Marine Engine or direct from Ken Cook at
www.outboardbooks.com
Fuel mix is 50:1 (even if there are decals that say 100:1 .. they should have been removed)
Current recommended plug is RJ6C gapped at 0.030"
Your carb I believe has two adjustment needles. The upper one is the slow speed needle and its basic setting is 1½ out from gently seated
The lower one is the high speed needle and its basic setting is 1 turn out.
The full instructions for setting these have been published by Joe Reeves and are as follows
Carburetor Adjustments - Two Adjustable N/Vs
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle va /lve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, wating for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
Before using it it would be wise to change the gear case oil. If the old oil is milky it indicates water ingress and you need to establish the cause and replace the seals.
It might also be sensible to change the water pump impeller or at least be sure it is not over heating
You will find parts lists and diagrams at
Shop.Evinrude.com
BTW do not undo the screw in the top of the cover. The recoil starter will fall apart if you do and the spring will escape like a caged tiger!
