Hello i have a 87 volvo aq131a and i have white milky oil all over the engine and on the bottom of the inside of the boat,came out from the crank case breather.
How did this happen the boat idles nice no problem and the temp gauge is at 195f
and have good oil pressure.
The motor is a closed cooling and antifreeze level is ok.
Had a look at plugs,clean and ok
Had a look through the oil cap and everthing is white thick stuff and i see clear water droplets everwhere and the cam is starting to rust .
Anybody know what is happaning
Thank You for th help
