1stboat
A couple of months back I replaced my PDS bearing because it was shot. Everything was fine for a couple of weeks. All of a sudden the engine ( I think its coming from the engine) started making what sounds like a knocking noise when the boat is in neutral. The u-joint snap rings seem to have gone in just fine. I'm going to remove the drive shaft bellows and make sure one of the u-joint caps haven't come loose.
At first I thought it was my water circulating pump going bad, so I replaced it. The noise was still there after replacing it, so it appears that wasn't it.
Could some other bearing be the cause of the knocking noise? When in drive or under acceleration the knocking goes away and the boat appears to have no issues. It seems to be getting worse and worse. I don't want what ever the cause to go bad at the wrong time.
In case my signature doesn't show my drive or engine model, I have a 1994 5.7 GI mated to a AQ-C drive.
