Port counter rotation engine starts and runs perfect to about 2800 rpm. Although I give it more throttle it doesn't respond.Used to run at 4000. No misses or backfires. Carb swithched from starboard which ran 4000 , no change. Dist. rebuilt no change. Comp.. test well with in spec. Both filters changed no change.timing checkedat 5 degrees before tdc. new plugs and wires no change. Can set at 2800 and run for hrs on plane but something isn't right. Any ideas. I'm stumped and so is my mechanic.
