Kevin Conley
water out of supply hose (into bucket) from inner transom looks good up to 3000rpm, after that flow lessens, and is "airated", a mechanic friend said it's back pressure from exhaust getting by the waterpump plate and can be fixed by sealing the plate w/ silicone. Transom is completly under water. '87 Merc. 260, alpha 1 o/d. Tried all the usual stuff - new waterpump, thermostat, clear manifolds & riser, new Y pipe w/ flappers. ( needed due to leak at bottom ) I've replaced lots of o/d water pumps but never had a problem like this before. Does this explanation sound reasonable? has anyone else experienced symptoms like this?
