Results 1 to 2 of 2
  1. #1
    Join Date
    Aug 2009
    Location
    Plano, TX, USA
    Posts
    8
    Default Removal & replacementg of Steering Cable
    Recently bought a 89 Cajun 16' with 60 hp Evinrude with rack/pinion steering. Boat unused for year or two. Steering wheel is very hard to turn either way. Any suggestions as to how to remedy this problem other than replacing cable? If replacing, how do I remove the cable and replace? How to determine length/part number? Do cables come with rack & pinion or can old one be used with new cable? Are they all alike -- that is, will new one mate with old steering gear attached to steering wheel shaft? I need help!
  2. #2
    Join Date
    Nov 2002
    Location
    Mullica Hill, New Jersey, United States
    Posts
    1,810
    Default Re: Removal & replacementg of Steering Cable
    First of all you want to see if the problem is in the steering system or the motor. Disconnect the link arm that connects the steering cable to the engine. Turn the wheel and see how it turns. If it turns easy, try turning the motor by hand, more than likely, it is stiff.
    If the wheel still turns hard, remove the cable from the engine, or at least disconnect it and try again. The problem may be in the steering tube on the engine and it might be able to be cleaned and lubricated. Bottom line is to locate the source of the friction prior to throwing any money at the problem.
    There is no permanent fix for a tight cable, it has to be replaced. The identification numbers should be molded into the cable housing near the motor end. The new cable will come with the rack on the end, it's four bolts and out it comes.
    Make sure you clean out the steering tube and lube everything up good prior to reassembly. It may be less expensiveness to buy a new packaged system than buying the cable alone but you may need to do some alterations to install the new helm.
    Good luck
Similar Threads
  1. 88 HP Johnson steering cable removal
    By west500 in forum Johnson Evinrude Outboard Forum
    Last Post: 08-30-2010, 06:45 AM
  2. Steering cable
    By jmule98 in forum Mercruiser Sterndrive Archive
    Last Post: 07-16-2009, 07:51 PM
  3. Steering cable
    By holinwtr in forum Mercruiser Sterndrive Archive
    Last Post: 07-06-2009, 10:20 PM
  4. Steering cable
    By boatn4fun in forum Volvo Penta Gas Archive
    Last Post: 01-27-2009, 07:26 PM
  5. CABLE BUDDY%e2%84%a2 Steering Cable Lubrication System
    By pas_bon in forum Yamaha Outboard Archive
    Last Post: 11-24-2008, 06:42 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
