honda bf130 2004 long beep after run about 100 yrds
The beep beep beep is the alarm indicating you through a code when you disconnected it.
if you had the pgm panel installed, the pgm light would be lite.
You asked about installing it yourself. Yes, it is easy to do.
The cheapest way is to use a
32340-ZW7-000AH
PGM-FI Panel​
Should be used with fuel-injected
models BF115-225 if not using key
switch panel 36452-ZW7-100AH/AHR
or 36652-ZW7-100AH/AHR. Includes​
3 foot harness. 1 panel per engine
See it on Honda web site http://marine.honda.com/pdf/accessories/ml.rerap45a.MAC_Key_Switch.pdf
You also need
32185-ZW5-000
3 Wire PGM-FI Panel
Harness–BF115-225
16.5​
Foot Long:
Original
equipment harness connects PGM-FI
panel to engine.
Suggested Retail: $34.00
http://marine.honda.com/pdf/accessories/ml.rerap45a.MAC_Harness_Electric.pdf
You can probably order them from boats.net
Mike
PROBLEM SOLVED
THANKS TO ALL ON THE ADVICE AND INFO
I changed out the temperture sensor switch (the one located on the port side of motor about 4 inches from thermostat and 4 inches from top spark plug ) and the motor runs great .17 dallar part.
thanks again to all Randy
