Gunsmoke9150
doing the electrical testing of the ignition coil. Manual says to measure between Black/Yellow and "core". reading should be .38 Ohms.
wahat is the "core"?? Ground?
thanks
thanks
understand. just was wondering what voltage is required to "charge the CD" because it seemed pretty low at .4-.5 vDC.
Just to be clear, I would check black/yellow wire coming out of the CD unit to ground, pull the starter rope and measure vDC.
will check and let you know. that is the angle I was working yesterday but wasnt sure what the value should be.
thanks
