Click for Volvo Penta parts and manuals!
Results 1 to 8 of 8
  1. #1
    Default What engines mate with a volvo penta 280 outdrive
    What engines do mate with a volvo penta 280 outdrive. Anyone know???
    Currently I have a aq 130, I have been told that it is a general motors engine or block is that true?
  2. #2
    Join Date
    Apr 2007
    Location
    Posts
    666
    Default Re: What engines mate with a volvo penta 280 outdrive
    Nope, the AQ130 is the old standard straight up iron engine and it's a Volvo thru and thru. Nothing bolts to it but a AQ170 that is the same but 2 extra cyl's up front. Many engines have been used in front of an AQ series drive, it's all the different flywheel covers and exhaust parts that can be the nightmare re-powering. Your best bet is to find a rotted boat with the powerplant you want already mated to the 280 and scoop it up. Gearing is different for the amount of cyls in front of the drive.Trying to do it a peice at a time would bankrupt Bill Gates.
    [email protected] Gary's Marine
    Bandon, Or.
    Since 1979
  3. #3
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    If just speaking of drive match, any Volvo 4-cyl (130, 120,125,131,140,145,151...)will match. They all use the same ratio 2.15:1.
    That said, you may end up in other problems like engine mounts, exhaust etc.
    The 170 as mentioned above use a 1,95:1 ratio.
  4. #4
    Join Date
    Apr 2007
    Location
    Posts
    666
    Quote Originally Posted by haffiman37 View Post
    Did Volvo Penta make a different gear ratio for outside the USA? I've only known the AQ170 to be a 1.89:1.
    Bandon, Or.
    Since 1979
  5. #5
    Join Date
    Apr 2006
    Location
    Posts
    5,750
    Mixed it with a duo-prop ratio.
    Here is the general ratios that may be read out from the drive ID tag:
    B = 1.61:1 C = 1.89:1 D = 2.15:1
    In general, all 4-cyl runs D
    6 in-line C
    V6/8 and diesels B
    That said, the drives are close to bullet proof.
    I have run AQ200 on both C and D drives as well as AQD21 on a D drive without problems.
    Just watch out for 'minor' issues like splines in yoke and steering helm bolt size and get a suitable transom mount!
  6. #6
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,714
    B = 1.61:1
    C = 1.89:1
    D = 2.15:1
    In general,
    all 4-cyl runs D
    6 in-line C
    V6/8 and diesels B
    That is correct!
    Some of the 4.3L's, in the right hull, can also use the 1.89:1.
    I don't know what you are wanting to do, Jim, but minus exhaust issues, just about any engine (that has at one time or another used a Borg Warner flywheel cover), can be adapted to an AQ series out drive.
    Several years ago, a forum member was wanting to keep a 460 OMC KC engine, yet go Volvo Penta Duo Prop, but not in the DP-S version.
    He wanted to use the AQ series drive, specifically, the DP C drive.
    He was told that this could not be done.
    NOT so!
    The 460 has been equipped in the past with the B/W pattern flywheel cover! I think mostly with jet drives.
    I was able to show this man how to make the AQ series connect up and work using the B/W--Volvo PDS adapter housing.
    He is currently using and enjoying his 460 BBF w/ a DP-C1 drive..... and happily too.
    If you have the time, and if you know which parts to use, you can do many out of the ordinary conversions.
    However, it is often best to stay with an OEM set up.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
  7. #7
    Hey Jim R. I may be able to make things easy for you. I have a Volvo Penta 130a with a 270 outdrive that I need to get rid of. May be easier to replace the whole unit.
  8. #8
    Quote Originally Posted by royscott View Post
    Hello , Iam not jim r , but am interested in your 130/270.
    jevans2
Similar Threads
  1. Help with Volvo Penta AQ140 / Volvo 280 outdrive
    By IronWolf in forum Volvo Penta Gas Engine Forum
    Last Post: 08-15-2010, 04:37 AM
  2. What engines will mate with 280 outdrive
    By medic_one in forum Volvo Penta Gas Engine Forum
    Last Post: 09-07-2009, 07:44 AM
  3. VOLVO penta KAD44P EDC engines do not start
    By mbarak_ahmed in forum Volvo Penta Diesel Archive 2004-2009
    Last Post: 11-28-2007, 01:44 PM
  4. Volvo Penta AQ 231 Petrol Engines
    By Tony Tenerife in forum Volvo Penta Gas Archive
    Last Post: 02-05-2006, 06:56 PM
  5. Need used volvo penta outdrive
    By Fletcher Steele in forum Volvo Penta Gas Archive
    Last Post: 10-26-2002, 11:42 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
