Results 1 to 3 of 3
  1. #1
    Default Wizard Outboard Motor
    I have a wizard outboard motor trying to find parts for this, and it is a model #WN7A Serial # 824511. Needing to find a water impeller for it, and maybe other parts. Any help would be appriciated.
    Bill
  2. #2
    Default Re: Wizard Outboard Motor
    did u find what u were looking for im having same problem have a 7.5 wizard engine looking for water pump
  3. #3
    Join Date
    Jan 2007
    Location
    Edgerton, Minnesota,
    Posts
    327
    The WN7A is made by Mercury in 56-57 as a 12HP motor but your serial number doesn't match unless the 8 is a 9. There is a 7.5 listed as being made in 59 by Scott. Couple of possible sources are http://home.earthlink.net/~flyingscott/ and http://www.wizardoutboardforum.com/. Also more info at http://www.aomci.org/ either thru the links tab or the Ask-A-Member forum.
Similar Threads
  1. 5 hp wizard point gap setting
    By samjr04 in forum Other Outboard Motors
    Last Post: 07-23-2008, 08:08 PM
  2. Fuel mix for 1971 5hp wizard outboard
    Last Post: 07-13-2008, 04:23 PM
  3. Wizard Outboard motor parts
    By larry koob in forum Chrysler Force Outboard Archive
    Last Post: 05-08-2006, 02:00 PM
  4. Wizard 6 hp motor
    By Soggydog in forum Other Outboard Motors
    Last Post: 04-25-2003, 09:49 PM
  5. Prop and thrust plates for WIZARD 10hp outboard
    By roger fultz in forum Archive 2003-2009
    Last Post: 07-18-2001, 09:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
