Results 1 to 10 of 10
    Default Alpha One Dies Going Into Gear
    I am wondering if this problem is related to, or just coincidental to a repair I just did. I replaced the water pump in my '88 outdrive (engine is the 4.3L V6), and after reassembly, the engine starts fine and runs well at any rpm when in neutral. But when I try to put it in gear, forward or reverse, it just dies - won't even get into gear before stalling. I thought perhaps we didn't have the shift shaft properly in gear as the manual states, so I took the lower unit off again, believe I have it properly in gear when putting it back together, but same problem. Somehow I'm thinking this is more electrically related than the shifting, but I've not done much work on this boat except the usual maintenance chores, so the problem has me baffled.
    Any help would be much appreciated. Thanks!
    Default Re: Alpha One Dies Going Into Gear
    im not a boat mechanic you will have to wait for some of them to anser but ive learned some things from them, there is a shift interupter on the starboard side of the motor,it killes the motor for a split second while comong out of gear, there is two cables there ,one from the shifter ,and a shorter one going to the drive ,there is a little switch with a vee notch,the v notch moves when shifting out of gear,it helps disangage the gears, but wait for one the seinors to anwser they no alot more than me and can tell you why its doing it
    Thanks I saw that mentioned when searching here, but now am home so I don't have my manual with me to look that up. The engine did overheat last use before replacing the pump, so I'm wondering if all that is related. Thanks again, I'll look forward to the other repleis.
    Jul 2008
    Northboro, Ma, USA
    6,070
    Yes
    the short shift cable typically hugs the exhaust rams horn at the back of the engine and when you overheat your motor the cable gets cooked and causes resistance and resistance is what causes the interuptor switch to be made when shifting OUT of gear......
    Look at the back of the engine, looking at the engine look at the left side and or follow the short shift cable routing and look closely at the point it comes in contact with the exhaust.
    Thanks for the prompt reply. So the question is, do I assume a bad switch and replace it, or do something to free up the cable/shifting?
    Thanks again,
    Mark
  6. #6
    Mar 2008
    Manalapan, nj, usa
    3,727
    So the cable is melted ? You looked ? Ghost took time to post what to look for.
    So say the cable is melted, you think it has to be replaced ? If you think yes you would be right.
    So when you do route the new cable maybe wrap that one spot in foam, something so it doesn't happen again.
    Good luck !
  7. #7
    Jun 2006
    Spotswood, NJ, USA
    5,554
    If you replaced the impeller from a overheat condition, the shift cable is fused where it passed around/over/under the exaust pipe.The switch is working properly.a new shift cable should solve this problem
  8. #8
    Many thanks to all for the info
  9. #9
    Sep 2003
    New Tripoli, PA, USA!
    17,311
    My 1986 305 Alpha One did that. The cure was to pull the outdrive and lubricate the shifting arm on the boat side (that was sticking). Totally cured the problem.
    Jeff
  10. #10
    Jun 2006
    Spotswood, NJ, USA
    5,554
    Yes, corrosion does that, melting the shift cable also does that too. Another cause is forcing the lower unit back on .
  1. 197 8- 1980 8 hp 8m Mariner dies when put in to gear...
    By kitzmann in forum Mercury Mariner Outboard Forum
    Last Post: 06-23-2010, 06:21 PM
  2. Engine dies when put in gear
    By Hakuna Matata in forum Crusader Marine Engine Forum
    Last Post: 06-09-2010, 09:37 PM
  3. 90 HP dies when put in gear
    By gneg1056 in forum Johnson Evinrude Outboard Archive
    Last Post: 06-01-2009, 06:22 PM
  4. 77 Evinrude dies when put in gear
    By ron62sparks in forum Johnson Evinrude Outboard Archive
    Last Post: 05-24-2009, 06:28 PM
  5. Malta dies when put in gear
    By dominik in forum Archive 2003-2009
    Last Post: 04-20-2008, 04:02 PM
