Click for Bukh manuals!
Results 1 to 6 of 6
  1. #1
    Join Date
    Aug 2010
    Location
    Lake Macquarie NSW Australia
    Posts
    5
    Default Bukh DV24 - Pressure in sump
    I have a Bukh DV 24 with pressure in the sump. The oil is thick but i dont think that it is water. can anyone assist. I also dont have a manual(just brought boat), does anyone know where I can get a manual from.
  2. #2
    Join Date
    Aug 2009
    Location
    Hobart, Tasmania, Australia
    Posts
    114
    Default Re: Bukh DV24 - Pressure in sump
    Gday Mark,
    It may be a blocked grank case breather or cyl gas blowby, how does the engine cold start? If lube oil has water dilution it will change colour towards light grey depending upon %.Sounds like engine is due for a service-- oil, filter etc at your operating area a good quality 15/40 diesel oil is whats needed.The prices of bukh parts in aus will floor you, take the old filters to repco for a match, if i find the euro site re manual i'll post latter.
    Cheers.
  3. #3
    Join Date
    Aug 2010
    Location
    Posts
    5
    Thanks for the reply. The engine starts cold OK but the pressure in the sump becomes big problem. As I dont have a manual at the moment it is hard for me to fault find. Because the oil is so thick I cant remove via the dip stick and I cant reach the drain plug which I have to work out.
  4. #4
    Join Date
    Aug 2009
    Location
    Posts
    114
    Mark,
    First step clean crankcase vacuum valve located in engine oil filler cap with kero, when clean and workimg this allows the crankcase to run a slight neg pressure.The motor has probably been running to cold or using the wrong oil this is the cause of most sludging.You will need to run the engine 20-30 mins to thin oil to help with evacuation via dipstick, if no joy add a couple of litres of diesel and crank hot engine over with stop lever in the kill position, repeat as required. Google, manuals Scheepmotoron for dv24 info.
  5. #5
    Join Date
    Aug 2010
    Location
    Posts
    5
    Thanks for the reply. Dont have an oil cap only a screwed plug, unless I am looking at this wrong. Looked up Scheepmotoron and go nothing. Is the name wrong?
  6. #6
    Join Date
    Oct 2011
    Location
    New Zealand and Colorado
    Posts
    3
    Hi Mark, just stumbled on this year-old thread. I'm in Pittwater with a DV36 and just wondering what the outcome of your "pressure in sump" issue was? Was it the oil filler cap valve or something else? Mark
Similar Threads
  1. fuel in the sump
    By madhatter in forum Detroit Diesel
    Last Post: 05-29-2010, 10:32 AM
  2. Tapits on a dv24 help
    By vtrgirl in forum Bukh
    Last Post: 11-21-2008, 04:52 PM
  3. 43l v6 leaking oil pan sump
    By biddison2200 in forum Mercruiser Sterndrive Archive
    Last Post: 08-21-2008, 03:07 AM
  4. Hand Starting DV24
    By tdw in forum Bukh
    Last Post: 08-13-2006, 10:40 AM
  5. Sump conversion
    By bym in forum Archive 2002-2006
    Last Post: 01-27-2002, 05:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
