We have a volvo 2003T with water in the oil and difficult starting symptoms suggesting water in the cylinders. Apart from head gasket problems, has anybody experienced water backing up through the exhaust system?
Having difficult starting symptoms suggests that it is not simply due to the oil cooler or/and water pump seals.
The syphon valve seems to work properly although it could be mounted not high enough above the water line. Could this induce water to trickle back when stopped?
