hi, my boat was taken out of water to repair throatle linkage, when it was put back all my gauges where dead, mechanic checked and said there was power to them and didnt know why tachometer werent working. when i start boat tach goes to 7 grand and stays there. fuel doesnt work at all. any suggestions. thanks in advance.also when they installed new new telafex throatle box my beep fo engine start doesnt work.also is yamalube 2w oil okay for tohatsu 90 hp 2 cycle motor, if not what should i use. thanks
What is your model? You need to verify wiring. Possibly your ground is incorrect, or something was changed when the RC box was installed. If you leave the tach pegged all the time, you may burn it out. There are wiring diagrams at http://www.internetoutboards.com/PartsCatalogMenu.htm
The Tohatsu RC box has the beeper inside it. Does the new RC box also have it?
