Yep, Ditto!Those erode from the inside so their condition isn't allways apparent from the outside. It's an item that commonly wears away and causes loss of suction so it's a good idea to keep an eye on it. At $40 for the fitting and gasket, I think they're relatively cheap compared to the potential headaches. It's much easier to change out with the outdrive off. At the very least, would be a good idea to inspect the inside closely for out of round, corrosion, cracking, pitting, or anything else off normal.
You've touched on the most important part of this.Thanks,
I just picture broken bolts and more grief but the recommendation was for a touch of heat and patience. I'll order that part for peace of mind.
