Recently rebuilt Crusader 270 after a spun bearing. Plastigauged all bearing journals’ and all were at min specs. Oil pressure was 50 psi at 1500 rpm, now it’s at 80 psi at 1500 rpm. Less than 5 min on rebuild. Is this normal this new after rebuild?
It's normal for a high rpm race engine. So, a couple of questions. How are you measuring the oil pressure? And, was any top end work done; as in new lifters and/or cam? 2000 is a better first start rpm after a rebuild, but that's beside the point.
Did the pressure rise from 50 to 80 at 1500 during this few minutes? That seems suspect to me, in a healthy engine, even after a fresh rebuild.
OK, lets say the 80 psi is real and is now your cruise pressure. That really loads the drive system for the oil pump, and perhaps subjects the filter can to a bit higher than it needs to be. The real issue can be a COLD start. Its now the middle of summer, what happens with a 40 deg start? That will REALLY stress the drive system. You would want a 0W/40 synthetic to even attempt such a start, in my opinion. And, use a strong filter, maybe a K&E, Mobile 1, etc.
Sorry, if that pressure is real, I'd put a stock pump in there.
