Re: 305 Runs Great Cold...Runs Poor Warm
Boat is a 2003 Bayliner with a 5.0L Mercruiser power plant (GM 305). It is MPI, no carb, although it does have a big single barrel butterfly valve where a carb would be (sans a fuel jet). I have never seen an EFI set up like this before. I have always seen individual lines running to each cylinder. I guess that is just my inexperience with this kind of fuel injection.
I replaced the fuel filter (was going to do that anyway) and low and behold...It did nothing to fix the problem...I was hopeful, even if I did not think it would work.
I have ordered a new hall effect sensor, should be a few days. Meanwhile all I can do is watch the beautiful passing weather and stare wistfully at the serene early morning glassy water which mocks me.
Does anyone have ideas of how I can test this thing to be sure this latest part is actually going to fix the problem? I guess this is a lesson in patience. Note to self: Never ask God to teach me patience.
I saw the coil suggestion, and I recognize that is also a possibility. How common are thermal coil problems? I also saw the question on fuel, and while that may potentially explain cutting out, it would not explain backfiring.
I ran a timing light on this to see where things were. Stupid crank is only marked with a TDC line and block only has the one notch. No additional marks to adjust timing. I read somewhere that you cannot adjust timing on this engine as it is all computer controlled using the hall effect sensor to signal where the crank is. I also saw something talking about a purple and white wire which I have not yet located (you need to be a contortionist to work on a boat in wet dock -- Had to dig a screw out of the bilge with a large magnet. fun fun fun). Timing is currently after TDC (although I have not found the purple and white wire), and I believe it should be 8 degrees before. I have not figured out if this is normal or not. I do know that when the boat starts running like crap, the timing position is still nice and consistent (albeit advanced at normal operating speeds). If you drop it back to idle when it is running crappy and convince it not to die, the timing still appears good.
How much fluctuation in the position of the timing mark is considered normal and acceptable?
Any more ideas on things to test, or how to test them? I am open to suggestions and anxiously awaiting a part. Is it here yet? How about now? Darn....
Oh, I almost forgot....Temperature is rock solid, so the motor itself is not overheating, even if some other part is thermally freaking out.
Thanks again for all your helpful ideas!
