Results 1 to 7 of 7
  1. #1
    Default 1999 25hp johnson
    i have a 1999 25hp johnson motor and when i used it last it had some problems. when in idle and slow speed it works fine but when i give it some gas the engine revs up and down and when i trottle back it works fine. any suggestions.
  2. #2
    Join Date
    Jun 2010
    Location
    Milton, Fl
    Posts
    546
    Default Re: 1999 25hp johnson
    fuel problem, good gas, check carbs, check fuel pump.
    do comp check, spark check, and then did the fuel checks.
  3. #3
    engine was checked by a mech when i bought it ,new plugs,good spark,clean carb,i was wondering if it could be the blade ? new to this and was wondering if there is anyway to check.
  4. #4
    Join Date
    Mar 2010
    Location
    Whidbey Island
    Posts
    171
    I agree with coueytwo...it sounds like a fuel problem. How old is the fuel? Is it hard to start? When was the carb cleaned and who did it?
  5. #5
    the fuel was just baught,and for the carb it was serviced by a qualified mec before purchase.
  6. #6
    it starts the first pull since i had it.
  7. #7
    Join Date
    Jun 2009
    Location
    Jacksonville, AL
    Posts
    180
    What model is this engine?
    Does it have a sensor assembly?
    Greg
    Owner-Anniston Marine
    Jacksonville, AL
Similar Threads
  1. Cant get it to start 1999 25hp
    By dawson584 in forum Mercury Mariner Outboard Archive
    Last Post: 12-21-2008, 01:25 PM
  2. 1999 25hp How to clean the carburator jet
    By mmanevbg in forum Suzuki Outboard Archive
    Last Post: 12-14-2008, 10:59 PM
  3. 1999 25hp Suzuki No Spark at All
    Last Post: 12-07-2008, 10:19 AM
  4. 1999 25hp merc no forward or reverse
    By john_k in forum Mercury Mariner Outboard Archive
    Last Post: 06-06-2007, 11:12 AM
  5. 1999 Yamaha 25HP question
    By alabass in forum Yamaha Outboard Archive
    Last Post: 03-19-2007, 04:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
