1996 mercury force question
zebbman
i have a force elpt serial oe192718 1996. want to replace the propeller and wanted to know the procedure for it...also which prop to use for top speed. one im replacing is a 10.5 X 13p
In the hub of the propeller there is a nut with a tab washer. Bend the tabs on the washer, unscrew the nut, the propeller will slide off the shaft. As for what prop to switch to, what rpms are you getting with your current prop at WOT?
honestly dont know. tac is not working. but the prop on it has obviously been repaired as it is much smaller. its on a 16 foot spectrum bass boat. lust want a better top end. i got a new one with the boat that is the same prop but much larger. im going out sunday and will check it then..thanks
