How would determine if raw water or coolant side is causing to be too hot? And how bad is the 183 temp? Other side runs about 170.
1) Pump looked fine.
4) Disconnected raw water inlet and outlet hoses from u-cooler. Back flushed u-cooler using 80 psi dock pressure. Water rushed right through cooler. A few tiny pebbles came out. No obstruction apparent.
6) Visually inspected raw water flow at idle. Appears about the same on both sides. Good flow. Steam is similar on both sides at cruise, at least from the bridge there are no major differences.
Still have nearly 20 degree temp rise at cruise on the affected engine. (And I cruise in 65 degree sea water).
I guess I'll replace both 160F t-stats with 180F t-stats. From there no temp. rise will be apparent. Not much of a fix, though, unless the t-stat on the affected side only opens part way.
