2005' 225hp Tilting problems
dregan
I have twin 225hp Yami's that will tilt up and down without any problems when in operation. I always tilt the engines out of the water at the end of day. If I come back the next day the starboard engine will be in the down position?? What could be causing this??
Thanks, Dan
Re: 05' 225hp Tilting problems
you have a pressure leak down. check and make sure the bypass screw is tight.
if it is and it still leaks down, you may need a seal job. your service manual will tell you how to test the T&T system
