3pointstar
Hi -- Brand new to this forum!!!
I have a 1976 Mercruiser with 605 hours -- yes that is correct. The engine has been bullet proof and exceptionally maintained.
Two questions.
1. What is the normal operating temperature -- currently after a normal cruise the temp is about 155-160. When I run it hard it will get up to 180. The temp returns to the 155-160 range upon idle. I have had the impeller replaced a few times -- from lack of use -- and it seems this is a little high.--- Thoughts?
2. After a hard run WOT for 20 minutes if I make a sharp right (starboard) turn the engine may sputter and stall -- it starts right back up -- Any thoughts?
Other than these items everything with the boat (Browning Mustang II) has been great. As a side bar - with the exception of routine service a starter and trim pump and just last year a new prop-- have been the only things replace on the engine. In regards to the boat -- the only item that has been replaced has been the carpet -- Inadvertent gas spill that pulled the orginal carpet up. Everything thing else is orginal
Thanks in advance
3 pointstar
Two questions.
Thanks in advance
3 pointstar
