Finally got the engine running again. The Carter boost pump feeding the high pressure dual stage pump was toast. I think it clogged up the injectors with all the white powder corrosion from that pump. It idles and runs fine up to half throttle, after that it stutters and stumbles like it's out of fuel. I'm pretty sure injectors are all clogged up. Fuel pressure is fine (35-40).
Is it a standard ford injector set that I can get cheap? Or do I need to pay $200 for the local guy to diagnose them ($25 each).
