Justin3085
Port engine power loss at higher RPM
I have a 1985 Silverton SC with twin Crusaders. Took a trip to a local bar by boat only a 15 mile trek one way and the boat ran perfectly. On the way home, I had an issue where the boat slowed approx 5 knts. I noticed both engines temp went up about 10 degrees. There is a large amount of sea grass around so I did what I could to blow it out. Noticed a 10 degree drop in temp. Happened 1 more time on my way home and that was it.
Today, I went about 9-10 miles ran perfect, stopped at the fuel dock and put in some fuel. (This dock turns over a large amount of fuel),
Ran another 8 miles into the inlet and the ocean and turned around because the biting flies were so bad it just wasn't enjoyable. On the ride back I was running about 3200RPM with no issues and got back to the area of the fuel dock. From here its about 2 miles of no wake... ran fine.
As soon as I got to speed up again and roughly around 2800-3000RPM something wasn't feeling right and it sounded like the port engine was 'missing'. slight vibration was noted also.
At first I thought I may have damaged the prop or shaft but testing each engine individually yielded no problems up to 2200 RPM. At one point my port engine stalled while at 1400 RPM. I couldn't get it started again until I gave that EVIL anti siphoid valve a few taps. Fired right up, then I gave it a little throttle and as soon as it got to 2500RPM that feeling of 'missing' started again. I thought maybe I had gotten fishing line or wire wrapped up but wouldn't I notice this even at low speeds?
Anyway I got back to the dock, fire up the engine (port) and gave her some throttle. No strange sounds no missing sounds (a few days ago at first start it did sound like it may have missed - litle bit of smoke from exhaust, cleared up once at operating temp)
Nothing odd with starboard engine either. My plan is to start with the fuel filters, spark plugs and anti siphon pain in the neck. Because there was a slight vibration is why I'm really writing otherwise I would change the fuel and plugs before I wrote this. The vibration is was concerns me. It doesn't happen until you hit 2500-3000 RPM.
I'm hoping after filters and plugs are changed it wont give me any hassles. Just wanted to know if anyone had a similar problem with something other than the fuel and plugs being an issue. What about timing? I would notice that at low RPMs also right?
Ugh <bash head in wall>
-Justin
-Justin
