I've been working like a madman to get back in after I hit "something" a couple of weeks ago. Rudder and strut were straightened, new shaft and one prop fixed and the other checked since I had the boat out.
I have everything back together but have two potential snags:
1) After I installed the new shaft, I noticed that the distance between the back of the strut and the back of the prop looked different. I measured the other side and sure enough it's about 7/8" - 1" difference between the two - the distance on the new shaft is longer. I then measured from the end of the shaft to the rudder and it's about the same difference.
Thinking that maybe the prop wasn't on as far as the other side, I compared how much of the shaft extends past the end of the prop and it's a difference of maybe an 1/8" between the two sides. A slight difference but not enough.
The shaft is in the right spot on the coupling end unless they milled the set screw hole in the wrong spot. It sits flush so I don't think this is my problem. I'm starting to think maybe the shaft is just an 1" too long or the taper isn't quite right and the prop needs to be farther back.
Would you guys worry about it? I can't imagine that an 1" would make a difference in steering from one rudder to the other. I don't know if it would make a difference at speed. I really don't want to take the shaft out again if I can avoid it.
2) I think I'll need to drop the back of the engine when I do my final alignment but one side is at its limit on the mount. Can I just remove the metal shim that there's there and replace it with a thinner one?
Does Crusader sell an engine mount shim kit with different thicknesses?
I think I have the rough alignment good, the prop spins easily with one hand and the shaft is pretty well centered in the shaft log.
Bob
Bob
