2005 225hp Yamaha rising oil levels
I just got back in from BC Canada yesterday after a 7 hr run with a 1hr break at customs.
I raised my motors to flush with fresh water and saltaway before storing when I realized I wanted to check my oils levels 1st. I lowered the engines and check the oil level. Both engines oil levels were high on the dip stick. I thought it might be because I had the motors raised so I let them sit 10 minutes. Still high so I stareted and ran them for 2-3 mins then let them rest again. Still high. I had this issue once before after the same trip a year ago but it was only one engine. I had the thermastats replaced on both thinking that that was the problem. I have had no other isuues all winter with oil levels on shorter trips 2hr +-.
I left the engines down over night and will check them again tonight.
Also oil smelled like oil I did not smell gas. Oil smelled warm but not burnt. Oil was not foamy.
Any Ideas or expieriences would be helpfull.
Re: 2005 Yamaha rising oil levels
what is horsepower and model number of engines?
was the engine still warm when you checked the level of the oil?
was the engine warm? when you checked the oil?
have you been using ring free, we have found that on four strokes carbon build up will allow fuel to bypass rings.Try running a heavy dosage per instruction on bottle
