1993 OMC cobra, 4.3, No Spark
Bryters
I left the ignition key on last weekend for about 4 hours while I played in the water. When I went to start the boat I had no spark. I checked my coil and I had 4.8 volts at the coil. I lifted the (-) wire on the primary and then I read 12 volts. I did an ohm test on the coil and it looks good but I could not get a spark when I tried to manually fire it. Does anyone know how to test the module in the distributor?
