So here is the issue. I have a 1990 four winns 170 freedom with a 3.0L OMC Cobra. It sat for a year and was never run . I actually had some time to use it this year so I took it out and had a great time . . . . . for a little while. I have probably put 20 hours on it since the start of summer. It was running great and all of the sudden it started to sputter and die out on me when ever i had anything electrical going. So i took the negative cable off and it died. Replaced the alternator and things were good, for about 45 minutes. Then next thing i knew it was sputering when under any load, but mostly when i trim the motor . I read on here that someone else had the same type of issue that just so happened to be the coil. I figured what the heck , why not try it , its only 25 bucks. Fixed the problem for about 1 hour, then it has been doing it again. I am really at a loss. Here is a list of everything i have done so far :
Changed oil
Plugs
Ignition coil
points
condenser
alternator
added a 2nd battery and a 2nd ground to the motor
fuel filter
checked the tank itself , no debris at all
any ideas???? Thanks so much
Dave
Changed oil
Plugs
Ignition coil
points
condenser
alternator
fuel filter
Dave
