Boat listing to one side
I took a look at the rot doctor and emailed them. It seems like it can save the wood and no need to fiberglass with that stuff. They said paint it on in 3 coats then its good and will waterproof new wood old wood and help the wood be stronger again .
I cut two 18" holes in the back and in front of the seat. THe back half of the boat held water saturated the front was dry as a bone but the plywood showed the same rot as the back though
If the plywood is rotting, you will have to check that the Fibreglass is still adhering to the timber.
I found with mine, that the timber was easy to pull away from the fibreglass, and using a steel ruler, it was easy to slip it between the two surfaces.
But, as Chief says, if you can enjoy it this Summer, ...................
Bruce.
