Page 1 of 2 12 LastLast
Results 1 to 30 of 35
  1. #1
    Default Boat listing to one side
    What do I have to do to correct the boat listing to the port side. I have a 86 searay Seville with a merc 140 and Alpha one outdrive. I have put a new prop on the boat but its the only one I have used so far and would not know what another prop would do while riding. No matter how many people are on the boat it still does it also
  2. #2
    Join Date
    Feb 2009
    Location
    Lindisfarne, Tasmania, Australia
    Posts
    452
    Default Re: Boat listing to one side
    Sounds like too many people are sitting on one side.
    But, seriously, there has to be a loading problem somewhere.
    How does it sit when empty?
    Have you water trapped in any of the buoyancy tanks, if any are fitted?
    Bruce.
  3. #3
    It still list to one side even when its only me in the boat and I dont weigh verymuch. as far as a tank I dont even know if I have any or where they would be
  4. #4
    Join Date
    Mar 2008
    Location
    Manalapan, nj, usa
    Posts
    3,727
    hidden water in the hull or to much equipment on that side.
  5. #5
    Where do I look to find hidden water in the hull?
  6. #6
    Join Date
    Mar 2008
    Location
    Manalapan, nj, usa
    Posts
    3,727
    under the deck this a cuddy ? Maybe water logged foam ? Both myself and friend had water hidden under the cuddy deck in 2 compartments the drains were clogged.
    Only way to get in was to cut a access hole at a angle and when we were done glued back in the plug.
  7. #7
    Yes its a cuddy.I can see down to the hull where the doors open and close to it.
  8. #8
    Also would some type of trim tab correct the problem?
  9. #9
    Join Date
    Mar 2008
    Location
    Manalapan, nj, usa
    Posts
    3,727
    Water weighs 7 lbs a gallon got a 100 gallons of water or soaked foam thats 700 lbs.
    What trim tab gonna fix that ?
    How big a boat ?
    You got to get into the deck of the cuddy, you think i wanted to cut a hole in the deck i had nothing else to do that day ?
  10. #10
    Join Date
    Jul 2010
    Location
    everett, massachusetts
    Posts
    248
    Quote Originally Posted by Blunight77 View Post
    I have on my 20ft wellcraft stainless trim tabs mount on the stern one on each side about 6inches from the outer edge they are about 12x 4 inches .. they have adjustible studs to vary the angle ...for some reason my boat has starboard side lower than the port when running ..
    this could be because of the hull shape ...
    they work and reduce the power needed to get up to planning speed ..you don't need much angle to change this they look almost straight ...with bottom of the boat hull..
    some use more expensive trims tabs that you can adjust from the operators console ..
  11. #11
    Join Date
    Feb 2009
    Location
    Posts
    452
    No matter how oddly the trim tabs are adjusted, if the balance of the boat is out, it will list to one side when stationary.
    Got to be something wrong with the internals.
    Bruce.
  12. #12
    Im just trying to get a temporary fix till winter when I have more tine to work on it and repair everything that needs totally done
  13. #13
    I just cut a 2" hole in the back and the foam is saturated!
  14. #14
    Join Date
    Feb 2009
    Location
    Posts
    452
    Ah ha, so your buoyancy problem is directly linked to a flotation problem.
    Better get rid of the wet foam and replace it with new stuff as if you get full of water, you really stand a very good chance of sinking completely.
    Bruce.
    PS. Good to know you have found the problem though.
  15. #15
    Join Date
    Mar 2008
    Location
    Manalapan, nj, usa
    Posts
    3,727
    There are 2 schools of thought concerning foam, once when wet has to be removed, thats a given, but the question of to replace it and then it get wet again, why replace it ?
  16. #16
    Join Date
    Feb 2009
    Location
    Posts
    452
    My Gull Wing was advertised as "Unsinkable" due to the amount of foam that was inserted under the floor.
    So, when I removed it, and all the rotten wood that was a result of the water retention, oh, and the Carpenter Ants, I sealed up the compartments when I replaced the timber.
    Hopefully, I never hit anything to stick a hole in the hull to remove the buoyancy.
    Bruce.
  17. #17
    Join Date
    Jul 2010
    Location
    Posts
    248
    keeping the interior of the boat hull dry is important ..the more water trapped inside of the hull the hull life will be reduced ...
    water will attract insects ...
    correct the water problem when replacing the foam..
  18. #18
    I think the original owner who my uncle got the boat from left it outside and rain was let into it. The cover that came with it is older and was never water proofed so to me tells me how the water got into it
  19. #19
    Join Date
    Feb 2009
    Location
    Posts
    452
    The worst element for any boat with wood in it is to be allowed to soak up fresh water.
    That is what happened to mine, even though the drain plug was left out. The carpet soaked every drop, and once the rot started, it continued, out of sight.
    Bruce.
  20. #20
    I now just need to figure out all the materials I need to fix it
  21. #21
    Join Date
    Feb 2009
    Location
    Posts
    452
    When you pull up the floor, it will be UGLY.
    But, if your framing is good, you will only need to cut a hole sufficiently large enough so you can access the area, with tools like a handsaw to cut the foam into manageable sizes to remove.
    I used a panel saw to simple push through and cut in an action like using a paint scraper and a blow torch removing paint, without the blow torch.
    Bruce.
  22. #22
    I think the framing is bad too. Do you know if its 2x4 or plywood by any chance because it looks like it could be either. I pulled up the rug and some of the plywood a bit ago and it crumbled from being so water logged. I have built in seats how do I remove them without having to rebuild them?
  23. #23
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    If they are molded into the fiberglass you can try to undercut them to replace the floor. Go to www.therotdoctor.com
  24. #24
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    www.rotdoctor.com this is the correct one
  25. #25
    What do you mean by undercut them?
  26. #26
    Also how much of the cpes would I need?
  27. #27
    Join Date
    Feb 2009
    Location
    Posts
    452
    Sounds like you are about to do what I had to do. I was removing Wasp Nests, and I removed the carpeting and found that the flooring was a bit soft in places, so decided to get rid of the "loose" stuff, as I was exporting the lot home, from NY to Tasmania, and didn't want any surprises with Quarantine and Customs. Boy, was I surprised when I was confronted with the sight of thousands of live Carpenter Ants. Had to remove those, or hell would have broken loose if they were found. As it was, four eggs that I didn't find hatched on the trip over, and then the whole thing had to be fumigated with Methyl Bromide, at my cost.
    At least the old timber and ply framing came out easily, as it wasn't that well stuck to the fibreglass, and it didn't look like it was Marine Ply that was used in the first place.
    Now, I have a "New" boat.
    Bruce.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  28. #28
    I hope I can get it fixed quick to enjoy it this summer
  29. #29
    Join Date
    Feb 2009
    Location
    Posts
    452
    Hope you can too.
    Mine took a fair while as I had to replace ALL the wood, Re-upholster, Rebuild the engine and Leg, which meant chasing parts all over the world, clean out the complete fuel system, rectify wiring problems, rebuilt the crushed windscreens, and re-build the trailer and winch. Oh, and replace the trailer wiring and lights to Australian Standards.
    It all took 12 months, with a lot of time sourcing OMC specific parts, and waiting for them.
    We won't mention price. But, postage was horrendous.
    Bruce.
  30. #30
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    "What do you mean by undercut them?"
    Remove the flooring under molded seats that are part of the top half of the boat.
    "Also how much of the cpes would I need?"
    Read the directions about CPES on the website. There are other manufacturers of similar products; google CPES.
Similar Threads
  1. Replies: 14
    Last Post: 11-07-2010, 11:22 PM
  2. Having side to side play in copper coolant tube normal?
    By Huntfish320 in forum Johnson Evinrude Outboard Forum
    Last Post: 09-11-2010, 07:51 PM
  3. PORT SIDE RISER HOTTER THAN STARBOARD SIDE
    By Capt. Harry in forum Mercruiser Sterndrive Archive
    Last Post: 06-18-2008, 01:37 PM
  4. Boat Pulls Hard To One Side
    By sgnt_pepper in forum Volvo Penta Gas Archive
    Last Post: 06-04-2008, 04:31 PM
  5. Boat listing to left under power
    By kcphinney in forum Johnson Evinrude Outboard Archive
    Last Post: 06-27-2007, 09:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
