I have a 2006 PCM, GT-40 EFI engine in an older Shamrock. Although the engine is an '06 it only has about 30 hours on it. It's been running perfectly until about a week ago. It starts and idles fine. Sometimes at around 3200 - 3500 RPM the engine will momentarily shut off. It's as though someone turned the key off then right back on. Other than that issue it runs perfectly. When this happens the gauges do not go to the ignition off position. Since the symptom is like ignition shut off I cleaned the connections on the ignition switch although it didn't look corroded. I also used electronic cleaner. This effort ad no effect on the problem.
Any suggestions of where to look for the problem will be most appreciated.
KIX
KIX
