1988 yamha pro v 150hp carb
wen4222
I was wondering if someone could tell me how to adjust carb on the 150 pro v 1988, where do you start, is it one and a hallf turns out from seated or what. I was going to take mine off and clean them an was wondering if someone knew, before i start, they want to bog when you start off, but does good on top end, and you can smell gas sometimmes when your idling. I would appreciate any advise.
Re: 1988 yamha pro v 150 carb
is there anyone in here that knows about the carb on a yamaha 150 pro v? I have cleaned several carbs on other boat motors, I just need to know what the factory setting is on the adjustment. No one will answer me in here, for some reason every time I ask a question no answer.
your motor is year model 1985,
I do not have the manual for it.
the manual number is LIT-18616-V6-NK
maybe someone on here will have it.
