mercury blue band
Karlos22
I have a mercury blue band 50 HP 2 stroke thunderbolt motor that i have put on a 17 ft boat,
The engine runs with plenty off power when not in gear but when on the river and in gear it does not rev with any where near the power it has when just running any ideas ?
Also its a short shaft set up on a long shaft boat what affect will this have on the power tranasfer ?
:confused:
(1) 99.5% of all outboards run real good in the driveway or in nuetral,but as soon as you put a load on it thats where the fun begins.In order to get good results in diagnosing your problem I would check your compression on each cylinder 100+ is good.Take a look at your timing,good clean carbs,fuel pump okay,and do a link and synch.When that is all good you should have a good motor.Then you can start to calculate what size prop you have in conjuction with your boat,WOT RPM's.If your motor sits low enough in the water where it doesnt cavitate/ventilate worth a try.Also get your hands on a Manual.
The real danger of running a short shaft on a 20" transom is sucking air and frying the motor.
It might be fine at very low speeds, but if the boat ever climbs up on plane you might be in for a world of problems.
I suspect, if you want to keep running that motor you are going to either have to mount it on a bracket so you can lower it - take a saw to your transom - sell it and get a longshaft - convert it to a longshaft - or watch it weld it's pistons into the cylinders when the waterpump sucks air instead of water.
You can run a long shaft on a short transom and only have to worry about hitting bottom, but you really can't do it the other way around....
On a positive note, a 50 short shaft is a bit of a rare item so there is some demand from home boat builders who want to keep 1950's designs authentic - many runabouts in the 50/60's only had 15" transoms...
thanks for the replys guys can i act real dumb and ask what a link and sync is ?
also does anyone know what the motor should be timed at ?
looks like i had better lower the transom
Karl
Please read this and make sure your motor is compatible with these instructions.
Thanks to clamscanino for this info.
__________________________________________
Manual specs are different for each but this is close enough to get them all REAL close. This assumes nothing is broken or "wrong" with it. This also assumes that the timing pointer is properly adjusted (if adjustable) to accurately read TDC of the #1 piston.
This basic procedure will work for all the 2/3/4/6 cylinder inlines from 1960 to 1988. It's not for the newer 3 and 4 cylinder loopers.
Engine off
Disconnect throttle cable
Pull throttle arm to full throttle and verify carbs open fully. Adjust main throttle stop so that the carbs are JUST hitting thier own little throttle stops. The idea here is that you want the screw stop and NOT the carbs acting as the "final stop" for your throttle lever.
Return the throttle to idle, carbs should be closed. Set all idle screws to 1 3/4 turns out from lightly seated.
Remove all plugs except #1, hook a timing light to #1. Then follow the narritive.
When the throttle is in the idle position the carbs should be fully closed and the ignition retarded. It is the amount of retardation that determines your idle speed and is set later with the idle stop screw.
Timing Event One - throttle pickup.
As the throttle is advanced, the spark timing advances toward TDC and then to before TDC. As the timing is just passing TDC the 1st (minor)throttle pickup should hit and start to open the carbs. Use the timing light. Adjust the tang or trigger screw to make this a reality. All of them are speced different, but if the 1st pickup hits at 3-4 degrees BTDC advance - you win. Use the timing light with a friend cranking it to complete this setting.
Timing Event Two - max advance.
As you continue to advance the throttle the timing will advance while the carbs slowly open a bit more. The next adjustment is max advance, this is the point where the distibutor (or trigger) can advance no more. Set the max-advance stop to 21 degrees for "direct charge" crossflow inlines and 34 degrees for the older plain vanilla crossflows. Use the light, - err to the side of caution.
Right after max advance, further throttle motion should cause the second throttle pickup to hit and open the carbs to full. You already set that -now verify it.
Leave the throttle cable disconnected and go to the water. Leave the boat strapped to the trailer and back it in so it's deep enought to run. Have a friend crank it while you operate the choke and throttle. Warm it up at 1500 rpms's.
When "warm" adjust the idle stop screw for about 800 rpm and then ajust your idle needle(s) in (one at a time) till the motor stumbles. Quickly backing it out 1/2 turn from "stumble" will usually save it from needing a re-start. Do that for all the idle screws. Re-set idle stop for 800.
Now have your friend put it in gear (make SURE you are on the transom NOT in the water) and reset your idle stop for as low as you can get it. 500-600rpm is great if your old reeds will let it idle that low in gear. Now, re-adjust the idle screws, in to stumble, then 1/2 turn out. When you've gone back and forth with that a few times and have it "perfect" - adjust each one out 1/4 turn.
Reset the idle stop so that it's about 700-800 out of gear and 500-600 in gear. Sometimes bad reeds won't let you get that low, you've GOT to get it under 1000 in neutral (worst case) to avoid beating up your lower unit when you shift into gear, even 1000 is "bad" but like I said "worst case".
Now adjust (and hook up)the throttle cable so that with the shifter in neutral, there is light to moderate pressure holding the throttle arm against the idle stop.
Take the boat off the trailer and go out in the water. Try the hole shot. If it falls on it's face try adjusting the idle screws out 1/4 turn at a time (all of them together) till you can get a hole shot. You can kind of do this on the trailer at the ramp, but it's not really safe for you, the boat, or the tow vehicle.
You're done.
