cam specs 1987 2.3 liter
wmlaks
Does anyone know what the specs are on a 1987 2.3 liter. mainly the center line of the cam. thanks Michael
Re: cam specs 2.3 liter
I have a factory manual with 2.3 litre cam specs. Can you be more specific which specs you need?
there is: lobe lift, allowable and theorectial, cam End play, clearance, wear limits ... cam journal to bearing clearance and wear limit, Journal dia, max runout, max out of round, cam bearing location ... I will try to look it up for you.
I am trying to find out what the centerline is on a factory marine cam lobe lift and duration would be helpful as well
My manual has lobe lift as 0.2381 inches, allowable Lobe Lift Loss- 0.005 inches, it also mentions Theoretical valve lift @ zero lash as 0.390 inches for both intake and exhaust. I see no centerline spec listed in the manual.
