135hp johnson 1974 v-4 wont start help please got so much money in to it
david26
Will not start without startin fluid rebuilt the carbs heard befor the fly wheel snaped the key its fixed I think and new spark plugs and when its runin I can go out on the water then its a pain to start it after sittin its killin me has compression idk what to do
Re: 135 johnson 1974 v-4 wont start help please got so much money in to it
make sure ur choke,is wking properly,...what IS the compression...spark on ea cyl--?
ur post,is a lil difficult to understand regarding the flywheel key.
you need to use a timeing light on it to make sure it is firing on each cyl on time. you need to make sure the flywheel key is not still broken, ( I don't think it would run) but check anyway.
