Results 1 to 4 of 4
  1. #1
    Default interceptor thermostat housing/buehler
    looking for a thermostat housing for my 272 y block in my buehler turbocraft. Have not found much info on these so if anyone has any let me know. thanks.
  2. #2
    Default Re: interceptor thermostat housing/buehler
    i have all kinds of parts for the interceptor engines...show me a photo of what you need, or wkere it is needed. I am in the Toronto, Ontario area.
  3. #3
    Hello, i live in victoria bc & have recently acquired a 312 interceptor. I'm in need of the rh side or passenger side of a car thermostat housing as i do have the lh side which has the # 388 on the underside. From what i've heard the rh side has the # 387 is this correct? Thank you for your time & i look forward to your reply. If you wish to phone my # is (250) 658 8478.
    Thanks again. Paul crouch
  4. #4
    Quote Originally Posted by Chriscraftconnie View Post
    I need a distributor for a mid 60's y-block interceptor. Any ideas? Thermostat housing as well, but the inlet needs to come straight out from the block.
    Hal
Similar Threads
  1. 454 Mercruiser Thermostat Housing Reasembly
    By ehlien in forum Mercruiser Sterndrive Forum
    Last Post: 10-13-2009, 02:18 PM
  2. 4154 thermostat housing
    By crzhors in forum Perkins
    Last Post: 09-28-2009, 08:08 AM
  3. Broken old style thermostat housing
    By jclays in forum Crusader Marine Archive
    Last Post: 04-13-2009, 11:01 PM
  4. antifreeze in thermostat housing
    By hoseman in forum Mercruiser Sterndrive Archive
    Last Post: 11-20-2007, 09:02 AM
  5. Thermostat And Housing
    By edloh in forum Outboard motors archive 2000-2004
    Last Post: 02-06-2002, 08:26 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
