We have a 2003 BF115 which will not start. When we pulled the plugs, they were wet (water). We were able to get the motor running once and it ran fine for a couple of hours straight. Sounded good and ran normally.
After sitting the night, we could not get it started again. Same thing wet plugs. When you crank the motor without the plugs in a fine mist of water comes out. There was no rough water over night where we were parked, so I don't think it was sucking water directly into the air-intakes.
Called Honda about the the issue with Cracked heads and they said the symptoms for their Cylinder Head Cracks (Honda Service Bulletin #54), were rough idle and bad performance @2200-2400 RPM. It doesn't sound the same.
We are hundreds of miles from a Honda service center, so we are trying to get some suggestions.
