Page 2 of 2 FirstFirst 12
Results 31 to 37 of 37
  1. #31
    Join Date
    Jul 2007
    Location
    florissant, missouri, us
    Posts
    224
    Default Re: OMC COBRA 4.3Liter - turn key and nothing happens
    by doing it this way you will determine the path to check if the stater turns it will be from the sylinoid to dash to throttle if it dont it will be from sylinoid to starter but check all grounds first
  2. #32
    Join Date
    Mar 2008
    Location
    Manalapan, nj, usa
    Posts
    3,727
    Start your own thread people won't see this.
  3. #33
    Quote Originally Posted by boatin_bob View Post
    Being a 92 you should have 50 amp breakers, not fuses which you have already found, I forgot to mention for you to check the power trim, does it work?
    I have same issue but trim does not work as well, what does that mean? Any help appreciated
  4. #34
    I'm having the same problem... Only I've lost ALL POWER... Batteries good I was trying to jump start my boat and smoked my jump cart which knocked out my entire electrical system... Is it possible to fry both 50 amp breakers without them popping the buttons?? Thanks for any info you can give me.
  5. #35
    Join Date
    Jun 2006
    Location
    Spotswood, NJ, USA
    Posts
    5,131
    Default Re: OMC COBRA 1992 4.3Liter - turn key and nothing happens
    only if you hook things up backwards
  6. #36
    When I connected the battery charger it smoked the charger itself... When that happened I'm guessing it arced on something. I quickly unplugged it. But when I went back to try to power up I had nothing. I'm guessing I must of fried both circuit breakers... Just odd they didn't pop either button.
  7. #37
    Can you internally fry a breaker without popping the buttons on them??
Similar Threads
  1. 1989 3.0 OMC Cobra engine will turn over but not start
    By jamesallen18 in forum OMC Sterndrive and Inboard Forum
    Last Post: 10-14-2010, 05:43 AM
  2. installing new ujoints in my omc cobra 1992 4.3 L
    By bent99 in forum OMC Sterndrive and Inboard Forum
    Last Post: 09-11-2010, 08:49 AM
  3. 1992 omc cobra Shift problem
    By curt_garrett in forum OMC Sterndrive and Inboard Forum
    Last Post: 07-20-2009, 05:36 AM
  4. 1992 OMC 43 cobra question
    By deelan in forum OMC Sterndrive and Inboard Archive
    Last Post: 10-23-2007, 06:46 PM
  5. 1988 Cobra 50 GM wonbt turn up
    By dwlog in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-11-2007, 10:40 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
