Hello,
I desperately need some advice.
I can run the engine in my driveway ( hose attached to the ear muffs) no problem. I can rev the engine and it runs beautifully. Just after doing the above in my driveway I drive down to my boat ramp (1/2 mile away). I start the engine again on the trailer with the boat in the water. It runs great. I launch the boat and back away from the trailer and then the trouble starts. In both forward and reverse the enging runs rough. I try to increase the rpms with the throttle and it sputter and dies. I can do this numerous times and the same result.
I went through this process three times this past weekend. The engine runs in the driveway, but not when I drop the boat in the water.
Here are some things I have checked:
-Fuel Filter appears clean
-I squeezed the bulb while the engine was running and it was not
completely soft, but one squeeze made the bulb hard again
-The choke solenoid is not getting stuck
-The fuel lines from the tank to the bulb do not have any visible damage
Please advise. The engine is a 90 hp 4 stroke with 500 hours.
Thanks in advance,
Justin
Thanks in advance,
Justin
